Введение
How to disassemble device and fix restarting problem.
Выберете то, что вам нужно
Видеообзор
Xiaomi Redmi Note 9 Pro restarts - Power On flex replacement
Warm up the device to soften the adhesive.
Use plastic tools and a little isopropyl alcohol to separate the back cover.
Remove the Phillips screws that secure the motherboard cover.
Use a plastic opening tool to remove the cover.
Lift up the flex connector to disconnect the battery.
Remove the main cameras.
Remove the SIM tray.
Disconnect all flex cables:
Fingerprint sensor flex cable
Screen flex cable
Main flex cable
Coaxial antenna cable
Remove the Phillips screws securing the motherboard to the middle frame
Remove the motherboard.
Remove the Fingerprint sensor.
Remove the volume buttons plastic cap.
Use isopropyl alcohol to help remove the glued down flex cable.
Use playing cards to remove the flex cable.
7 человек успешно провели ремонт по этому руководству.
