Введение
Two tools required for the completion of this task include a PH1 screwdriver, and a prying tool.
All screws on this device are 10mm (0.393 in).
Выберете то, что вам нужно
Place the prying tool in between the hair straightener and the aligning cap.
Push forwards on the prying tool to pop off the aligning cap.
Remove the screws with the Phillips #1 screwdriver located underneath the aligning cap, one on each side of the straightener.
Use the prying tool to remove the aligning rods after the removal of the screws.
Gently separate each half of the hair straightener.
After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two screws located on the lower half of the straightener.
Use the prying tool to remove the hinge cover.
2 участников успешно повторили данное руководство.
6 Комментариев
is there a place where you can buy and replace the power cable, or the plug ?
the slip ring plug that is ..
part number would be helpful?
