Введение
Use this guide to assist with general disassembly or troubleshooting of your braille display.
Выберете то, что вам нужно
Remove the four bottom screws with a Phillips #00 screwdriver.
Remove the two screws with a Phillips #00 screwdriver on the logic board.
take out the main circuit like show in the picture
when you put it back together make sure mechanical cells are connected correctly
Еще один человек закончил это руководство.
2 Комментариев
great guide! how can I repair a VarioUltra 20? are the procedures similar? the device has a problem at point 4 of the sixth cell, the point moves unsteadily, should I replace this whole cell or is it possible to just repair point 4, which is defective?
which professional will likely be able to repair a braille display? should I look for an electrical engineer or other professional? I'm blind, I don't repair electronics, but I have a defective braille display that needs to be repaired. I live in a country where there are no companies capable of repairing this product. I do not know what to think. sending the product to a specialized company in another country is very expensive for me.
