Введение
If your battery is not working you can remove it and replace it following the step by step process. The battery can easily just pop out following simple steps
Выберете то, что вам нужно
Using a hair dryer, slowly heat the edges of the WorkPad.
Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
Еще один человек закончил это руководство.
