Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
Pull the top cover towards you until you can lift it up and off.
After the top cover has been removed, locate the disc drive on the right hand side of the DVD player.
Locate the four rectangular holes in the top of the black plastic disc drive.
You will now pry off the black plastic cover from the disc tray. Insert a flathead screwdriver into the slot indicated and press down while at the same time pulling the screwdriver towards the middle of the device. This will pop the plastic catch out to the side.
Without removing the first screwdriver, insert a second one into the hole indicated and do the same motion.
You can now lift up the right side of the cover. Don't pull up too far or you could break the clasps on the left side.
Now repeat this process, unclipping the catches on the other side.
You can now pop of the black plastic cover and see the exposed disc drive. If there is anything stuck inside that is jamming the drive, you can remove it.
Еще один человек закончил это руководство.
