Введение
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Выберете то, что вам нужно
Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
Flip the gas shutoff switch next to the motor to the left into the off position.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the right side of the machine.
Slide the cutter blade out from under the machine to remove it.
Use a 1/2 inch socket to remove the 130 mm-long bolt securing the chain guard.
Carefully tilt the sod cutter on its side.
Use a 9/16 inch socket to remove the nut securing the chain guard.
