Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the six external screws from the camera using a Phillips #0 screwdriver.
After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
Carefully squeeze the top right corner of the camera and pry off the external cover.
Continue to pull the external cover and it will come off cleanly.
3 участников успешно повторили данное руководство.
