Removing Canon PowerShot A550 Front and Back Covers
Выберете то, что вам нужно
  1. Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: шаг 1, изображение 1 из 3 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: шаг 1, изображение 2 из 3 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: шаг 1, изображение 3 из 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Removing Canon PowerShot A550 Front and Back Covers: шаг 2, изображение 1 из 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Removing Canon PowerShot A550 Front and Back Covers: шаг 3, изображение 1 из 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Removing Canon PowerShot A550 Front and Back Covers: шаг 4, изображение 1 из 2 Removing Canon PowerShot A550 Front and Back Covers: шаг 4, изображение 2 из 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Removing Canon PowerShot A550 Front and Back Covers: шаг 5, изображение 1 из 1
    • The camera should look like this once the front cover is removed.
  6. Removing Canon PowerShot A550 Front and Back Covers: шаг 6, изображение 1 из 3 Removing Canon PowerShot A550 Front and Back Covers: шаг 6, изображение 2 из 3 Removing Canon PowerShot A550 Front and Back Covers: шаг 6, изображение 3 из 3
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Removing Canon PowerShot A550 Front and Back Covers: шаг 7, изображение 1 из 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
Заключение
3 участников успешно повторили данное руководство.
Shaelyn Thomas
Участник с: 04/19/11
332 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-6, Regan Spring 2011 Участник Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 членов
Автор 22 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 31
За всё время: 4,258
