Removing DJI Phantom 2 Vision+ Case Top Shell
Выберете то, что вам нужно
  1. Removing DJI Phantom 2 Vision+ Case Top Shell, Remove the battery: шаг 1, изображение 1 из 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Remove the battery: шаг 1, изображение 2 из 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Remove the battery: шаг 1, изображение 3 из 3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. Removing DJI Phantom 2 Vision+ Case Top Shell, Propellers: шаг 2, изображение 1 из 1
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. Removing DJI Phantom 2 Vision+ Case Top Shell, Removing clockwise rotating propellers: шаг 3, изображение 1 из 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing clockwise rotating propellers: шаг 3, изображение 2 из 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing clockwise rotating propellers: шаг 3, изображение 3 из 3
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. Removing DJI Phantom 2 Vision+ Case Top Shell, Removing counter-clockwise rotating propellers: шаг 4, изображение 1 из 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing counter-clockwise rotating propellers: шаг 4, изображение 2 из 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing counter-clockwise rotating propellers: шаг 4, изображение 3 из 3
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
  5. Removing DJI Phantom 2 Vision+ Case Top Shell, Case Top Shell: шаг 5, изображение 1 из 2 Removing DJI Phantom 2 Vision+ Case Top Shell, Case Top Shell: шаг 5, изображение 2 из 2
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  6. Removing DJI Phantom 2 Vision+ Case Top Shell: шаг 6, изображение 1 из 2 Removing DJI Phantom 2 Vision+ Case Top Shell: шаг 6, изображение 2 из 2
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  7. Removing DJI Phantom 2 Vision+ Case Top Shell, Unplug GPS connector and remove case: шаг 7, изображение 1 из 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Unplug GPS connector and remove case: шаг 7, изображение 2 из 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Unplug GPS connector and remove case: шаг 7, изображение 3 из 3
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
Заключение
11 человек успешно провели ремонт по этому руководству.
David Hoyt
Участник с: 04/09/10
4 053 Репутация
Автор 41 руководств
Команда
Cal Poly, Team 25-89, Amido Spring 2010 Участник Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 членов
Автор 61 руководств
2 Комментарии к руководству
This guild will also largely work for the Phantom 3 (Adv./Pro) with the difference being that the phillips-head screws are T7s in the P3, and the 2mm Allen/Hex bolts are T8s.
anonymous 4102 - Ответить
Does anyone know what the size and thread pitch for the “2.0 mm hex bolts” are? I lost the screws and need a replacement.
Matt Hirsch - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 11,351
