Removing Dell Inspiron 1150 Optical drive
Выберете то, что вам нужно
  1. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: шаг 1, изображение 1 из 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: шаг 1, изображение 2 из 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: шаг 1, изображение 3 из 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: шаг 2, изображение 1 из 2 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: шаг 2, изображение 2 из 2
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  3. Removing Dell Inspiron 1150 Optical drive: шаг 3, изображение 1 из 2 Removing Dell Inspiron 1150 Optical drive: шаг 3, изображение 2 из 2
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
  4. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: шаг 4, изображение 1 из 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: шаг 4, изображение 2 из 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: шаг 4, изображение 3 из 3
    • Locate the optical disk drive on the bottom left hand side of the laptop.
    • Remove the single screw holding the optical disk drive in the chassis.
    • Remove the optical disk drive by gently pulling on the outer edge.
Заключение
Daniel
Участник с: 04/25/10
87 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 16-2, Maness Spring 2010 Участник Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 членов
Автор 9 руководств
Один комментарий
This guide is incorrect, please see http://support.dell.com/support/edocs/sy... for a version that will actually take the promised two minutes.
Nick - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 5,869
