Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Запчасти
Детали не указаны.
  1. Place the laptop upside down on a clean, flat surface. Locate the battery release button with the padlock symbol above it. Slide the battery release button towards the padlock symbol and hold it there.  Note that the button is spring loaded and will return if released.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Position the computer upside down. Remove the twelve M2.5 x 8-mm screws.
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  3. Position the computer keyboard side up. Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
  4. Locate the optical disk drive on the bottom left hand side of the laptop. Remove the single screw holding the optical disk drive in the chassis. Remove the optical disk drive by gently pulling on the outer edge.
    • Locate the optical disk drive on the bottom left hand side of the laptop.
    • Remove the single screw holding the optical disk drive in the chassis.
    • Remove the optical disk drive by gently pulling on the outer edge.
Заключение
Daniel
Участник с: 25.04.2010
87 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 16-2, Maness Spring 2010 Участник Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 членов
Автор 9 руководств
Один комментарий
This guide is incorrect, please see http://support.dell.com/support/edocs/sy... for a version that will actually take the promised two minutes.
Nick - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 5,655
