Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Turn the laptop so that the bottom is facing up.
Locate the panel that has an M on it and two air vents.
Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
Remove the panel.
After removing the panel, you will see two memory modules.
Locate the four spring clips that are holding the memory modules in place.
Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
Gently raise the memory module and lift it out of its socket.
