Введение
The purpose of this guide is to demonstrate how to locate and remove the 1150 Wireless MiniPCI Card.
Выберете то, что вам нужно
Turn the laptop upside down and locate the panel labeled C.
Unscrew the single screw holding the cover in place.
Lift up the cover and remove it to expose the Wireless MiniPCI Card.
Using a plastic spudger or similar, gently pry the grey and black wires off.
Gently pull the retaining clips away from the board so that the board pops up.
Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
Еще один человек закончил это руководство.
