Введение
This guide will show you how to remove the CPU Cooler on your HP Compaq dx2000MT. If your CPU Cooler becomes damaged or stops working than you would need to replace it or if you need to remove the CPU Cooler to get to another part of the computer.
Выберете то, что вам нужно
Turn off your computer and remove the power cable by pulling it straight out of its socket.
Remove the side case door by pushing towards the rear of the device with your hand.
Once you slide the door back, remove it by pulling it outwards from the device.
Remove the 3 pin power connector by pulling it towards the side of the device.
2 участников успешно повторили данное руководство.
