Введение
This guide will show you how to remove the power supply on your HP Compaq dx2000MT.
Запчасти
Никакие детали не требуются.
  1. Turn off your computer and remove the power cable by pulling it straight out of its socket.
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Remove the 2 Phillips #2 screws that secure the case door to the device. Remove the 2 Phillips #2 screws that secure the case door to the device.
    • Remove the 2 Phillips #2 screws that secure the case door to the device.
  3. Remove the side case door by pushing towards the rear of the device with your hand. This may take considerable force so keep pushing! Once you slide the door back, remove it by pulling it outwards from the device.
    • Remove the side case door by pushing towards the rear of the device with your hand.
      • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Remove the side case door by pushing towards the rear of the device with your hand. Once again, this may take considerable force. Once you slide the door back, remove it by pulling it outwards from the device.
      • Once again, this may take considerable force.
  6. Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device. Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device. Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
    • Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  7. Remove the 20 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device. Remove the 20 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
    • Remove the 20 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
  8. Remove the 4 Torx T15 screws from the rear of the power supply Remove the 4 Torx T15 screws from the rear of the power supply Remove the 4 Torx T15 screws from the rear of the power supply
    • Remove the 4 Torx T15 screws from the rear of the power supply
  9. Slide the power supply towards the front of the device Keep your hand underneath it! You don't want to drop it!
    • Slide the power supply towards the front of the device
    • Keep your hand underneath it! You don't want to drop it!
    • Then pull the power supply down and remove it from the case.
Заключение
7 участников успешно повторили данное руководство.
Logan Pace
Участник с: 12.10.2011
2 020 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 17-16, Regan Fall 2011 Member of Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 членов
Автор 17 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 9
За всё время: 2,448
