Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Removing the WiFi cables is essential for further disassembly of the laptop.
Запчасти
Детали не указаны.
  1. Slide the battery release latch towards you.
    • Slide the battery release latch towards you.
  2. Pull up on the battery to remove it. Pull up on the battery to remove it.
    • Pull up on the battery to remove it.
  3. Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs. Lift the cover from the right to remove it.
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. Use tweezers to detach the grey and black cables connected to the green WiFi card. Use tweezers to detach the grey and black cables connected to the green WiFi card.
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
Заключение
Allie Menard
Участник с: 12.04.2011
769 Репутация
Автор 13 руководств
Команда
Cal Poly, Team 24-56, Amido Spring 2011 Участник Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 членов
Автор 13 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 3,183
