Removing Minolta X-370 Lens Holder
Выберете то, что вам нужно
  1. Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: шаг 1, изображение 1 из 2 Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: шаг 1, изображение 2 из 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Lens Holder: шаг 2, изображение 1 из 1
    • Remove the batteries, making sure to note their proper alignment.
    Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
    Juliette Perry-Dumarquez - Ответить
  3. Removing Minolta X-370 Lens Holder, Bottom Cover: шаг 3, изображение 1 из 2 Removing Minolta X-370 Lens Holder, Bottom Cover: шаг 3, изображение 2 из 2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Lens Holder: шаг 4, изображение 1 из 1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Lens Holder: шаг 5, изображение 1 из 1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
  6. Removing Minolta X-370 Lens Holder, Lens Holder: шаг 6, изображение 1 из 3 Removing Minolta X-370 Lens Holder, Lens Holder: шаг 6, изображение 2 из 3 Removing Minolta X-370 Lens Holder, Lens Holder: шаг 6, изображение 3 из 3
    • Remove four 4.45mm screws and remove the alignment ring.
    • Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
    • Pay attention to the alignment of the interior metal ring and the black plastic ring.
    The photo is wrong, the red dot should be facing north, instead of west.
    Laura Ceja - Ответить
  7. Removing Minolta X-370 Lens Holder: шаг 7, изображение 1 из 3 Removing Minolta X-370 Lens Holder: шаг 7, изображение 2 из 3 Removing Minolta X-370 Lens Holder: шаг 7, изображение 3 из 3
    • Remove the two black stoppers.
    • Using the metal spudger, remove the two triangular hangers.
  8. Removing Minolta X-370 Lens Holder: шаг 8, изображение 1 из 2 Removing Minolta X-370 Lens Holder: шаг 8, изображение 2 из 2
    • Using the metal spudger, peel off the right leather cover.
    • Be careful not to tear the cover because you will need to use it again.
  9. Removing Minolta X-370 Lens Holder: шаг 9, изображение 1 из 3 Removing Minolta X-370 Lens Holder: шаг 9, изображение 2 из 3 Removing Minolta X-370 Lens Holder: шаг 9, изображение 3 из 3
    • Use the metal spudger to remove both the grip cover and the left leather cover.
    • Be careful not to tear the covers because you will need to use them again.
  10. Removing Minolta X-370 Lens Holder: шаг 10, изображение 1 из 2 Removing Minolta X-370 Lens Holder: шаг 10, изображение 2 из 2
    • Remove two 5.3mm screws.
    • Remove one 2.35mm screws.
  11. Removing Minolta X-370 Lens Holder: шаг 11, изображение 1 из 2 Removing Minolta X-370 Lens Holder: шаг 11, изображение 2 из 2
    • Remove the left and right plastic covers.
  12. Removing Minolta X-370 Lens Holder: шаг 12, изображение 1 из 3 Removing Minolta X-370 Lens Holder: шаг 12, изображение 2 из 3 Removing Minolta X-370 Lens Holder: шаг 12, изображение 3 из 3
    • Remove two 6.65mm screws.
    • Remove two 2.93mm screws.
    • Remove four 5.3mm screws.
    • Remove the black plastic lens holder.
Заключение
4 участников успешно повторили данное руководство.
Nick
Участник с: 04/19/11
525 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-7, Regan Spring 2011 Участник Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 членов
Автор 8 руководств
Один комментарий
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
Klaus Kohlhas - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 7,198
