Введение
You will be removing some leather grips, which you will reuse, to access some screws. Be careful not to tear these grips.
Выберете то, что вам нужно
Flip the camera so that the bottom is facing you.
Take a spare coin and unscrew the battery cover off.
Remove the batteries, making sure to note their proper alignment.
Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
Remove two 4.8mm screws.
Remove one 3.4mm screw.
Remove one 2.65mm screw.
Lift off the back cover.
Remove three 3.5mm screws.
Remove two 3.8mm screws.
Remove one 6.35mm screw.
Remove one 4mm screw. Lift off the disk.
Remove one 5.11mm screw.
Remove four 4.45mm screws and remove the alignment ring.
Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
Remove the two black stoppers.
Using the metal spudger, remove the two triangular hangers.
Remove two 6.65mm screws.
Remove two 2.93mm screws.
Remove four 5.3mm screws.
Remove the black plastic lens holder.
4 участников успешно повторили данное руководство.
Один комментарий
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
