Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Flip the camera so that the bottom is facing you.
Take a spare coin and unscrew the battery cover off.
Remove the batteries, making sure to note their proper alignment.
Remove two 4.8mm screws.
Remove one 3.4mm screw.
Remove one 2.65mm screw.
Lift off the back cover.
Remove three 3.5mm screws.
Remove two 3.8mm screws.
Remove one 6.35mm screw.
Remove one 4mm screw. Lift off the disk.
Remove one 5.11mm screw.
Remove four 4.45mm screws and remove the alignment ring.
Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
Remove the two black stoppers.
Using the metal spudger, remove the two triangular hangers.
Using the metal spudger, peel off the right leather cover.
Use the metal spudger to remove both the grip cover and the left leather cover.
Remove two 5.3mm screws.
Remove one 2.35mm screws.
Remove two 6.65mm screws.
Remove two 2.93mm screws.
Remove four 5.3mm screws.
Remove the black plastic lens holder.
4 участников успешно повторили данное руководство.
Один комментарий
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
