Выберете то, что вам нужно
Tool on left - PH000 screwdriver
Tool on right - iPod fix-it tool
Soldering Iron
Locate the 3 black screws on the bottom of the camera and the 2 gray screws on each side of the camera. Remove them with a PH000 screwdriver.
Locate the gray band that you removed the screws from; this holds the two halves of the camera together. Use an iPod fix-it tool to pry the gray band loose and remove it.
Use the iPod fix-it tool to carefully pry the screen from the logic board.
Flip the screen down. To disconnect the ribbon cable from the logic board, rock each end of the brown metal retainer that holds the ribbon cable in place until the ribbon disconnects.
Remove the two screws on the top edge of the circuit board to the right of the viewfinder.
To connect the new screen, solder the wires in place and connect the ribbon cable to the logic board.
Unthread the four wires running across the top of the viewfinder from the plastic brackets holding them in place.
Remove the two black screws threaded vertically into the top of the viewfinder. Loosen the flash and circuit board for more accessibility. This will allow for the viewfinder to be replaced.
Remove the two screws on the top edge of the circuit board, to the right of the viewer.
