Введение
This guide has been updated by iFixit staff! Read the new, official guide here.
This guide will show you how to remove the screws that hold the Logic Board into place. From here, some repairs may be done that require you disconnect all connected modules, and some may not require that you disturb the connections.
Инструменты
Запчасти
Никакие детали не требуются.
Place your device upside down and locate the battery compartment.
Find the phillips head screw securing the battery cover in the bottom right hand corner of the device.
Use the iFixit opening tool to carefully pry the battery out of the case.
After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
Place the battery cover on the top and gently screw in the phillips head screw to firmly secure the battery.
After this step you will have successfully relpaced your Nintendo DS battery.
Remove the following 7 screws securing the lower case to the DS Lite:
3 silver tri-wing screws (5mm long)
1 black tri-wing screw (4mm)
2 gold Phillips screws (4mm)
1 silver Phillips screw (3mm)
Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
Flip the unit over.
Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
Avoid touching the L and R shoulder buttons, because they pop off easily and are difficult to reassemble. Keeping the bottom case against your workbench will help hold them in place.
Carefully separate the two pieces by hand.
The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
When reassembling the cover, make sure that the power switch cover on the bottom case is in the off (down) position. Otherwise, the power switch cover can break the very fragile power switch upon reassembly.
After taking the bottom case off, remove two Phillips #00 screws that secure the logic board to the plastic case.
