Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
The screen of the Nokia 3100b is prone to cracking. This guide shows you how to access the screen and remove it.
Запчасти
Детали не указаны.
  1. Make sure your phone is turned off.
    • Make sure your phone is turned off.
  2. Press the button on the back of the phone and slide the back panel off.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Note the small metal frame that  hold the SIM card into place.
    • Note the small metal frame that hold the SIM card into place.
    • Gently pull back the tab and lift open the frame.
  4. Retrieve your SIM card.
    • Retrieve your SIM card.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Separate the front cover from the main body of the phone.
    • Separate the front cover from the main body of the phone.
    • Set the front cover, as indicated, aside.
  7. Remove the six outside screws along the edges of the phone.
    • Remove the six outside screws along the edges of the phone.
  8. Pull the screen assembly from the base of the phone.
    • Pull the screen assembly from the base of the phone.
    • Set the base of the phone, as indicated, aside.
  9. Carefully lift the keypad portion of the screen assembly from the circuit board.
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  10. Separate the screen from the circuit board.
    • Separate the screen from the circuit board.
    • Set the circuit board aside as indicated.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  11. Gently push down on the screen to pop it off of the assembly.
    • Gently push down on the screen to pop it off of the assembly.
  12. When the screen falls out the assembly, two white tabs will fall out with it, set them aside.
    • When the screen falls out the assembly, two white tabs will fall out with it, set them aside.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
Заключение
Sterling Fuentes
Участник с: 09.04.2010
82 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 29-64, Johann Spring 2010 Участник Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 1,632
