Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This will guide you through removing the sim card.
Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
Lift the battery case off of the phone.
Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
The battery should lift out with minimal resistance.
Once you have removed the battery, pull the tab on the metal sim card cover, and lift it up.
The sim card is underneath and can now be removed.
