Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will walk you through step-by-step on how to properly remove and replace the outer shell in the PlayStation 2 Slimline.
Выберете то, что вам нужно
Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
Use a spudger, flathead screwdriver, or fingernail to pry the five visible feet from the bottom of the device.
The sixth foot is located under the black VOID sticker. Remove the sticker before removing the foot underneath.
After all of the feet have been removed, locate the six 4.0mm screws on the base of the PS2.
Use a #1 Phillips screwdriver to unscrew all six 4.0mm screws from the base of the PS2.
If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
9 участников успешно повторили данное руководство.
