Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will show how to remove the printer's rear casing to access the interior of the machine.
Выберете то, что вам нужно
Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2 screws on the back of the printer.
4 участников успешно повторили данное руководство.
3 Комментариев
Thank you on how to do this. A little force is required to lift the top cover edges one by one to get the back cover off, but it does come off, without taking the top cover off. I think my solenoid is bad, as the printer takes two sheets of paper initially and then more right afterwards. The rubber pick up wheel seems to be fine after cleaning, as it picks up the paper without issue, just multiple sheets is all.
Thanks. I would have broken the top cover or back panel if I did not read your post. It take a little force to pull the back cover off while applying upward pressure to the top cover ends, one at a time. I think I have to replace the solenoid as the rubber pick up wheel pulls the paper up fine, but multiple sheets after the first rotation of the wheel.
