Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Запчасти
Детали не указаны.
  1. Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove flip  the cover.
    • Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove flip the cover.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Remove the cover with  a slight twisting motion. This is what the phone will look like after the cover is removed.
    • Remove the cover with a slight twisting motion. This is what the phone will look like after the cover is removed.
  4. To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base. To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base.
    • To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base.
Заключение
Еще один человек закончил это руководство.
manning
Участник с: 12.03.2012
21 Репутация
1 руководство автора
Команда
Clemson, Team 1-4, Benson Spring 2012 Участник Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 1,678
