Введение
This proposal will show you how to remove and clean your dishwasher spray arm out of a Bosch silence plus 50 dba dishwasher. Anyone can do it. This is a very straightforward process to remove and clean the spray arm.
Выберете то, что вам нужно
Open the dishwasher door to access the interior and locate the dishwasher spray arm
Remove the spray arm by grabbing the edge and slowly lifting it up with a bit of force.
Place the spray arm and soak it in a big bowl of warm, soapy water to help loosen any debris on the spray arm.
Equip your toothbrush (soft brush is fine too) and clean around the edges and nozzles to get out any dirt or debris.
Take out your spray arm, use any type of clean water source (e.g your sink) and rinse the spray arm thoroughly with warm water.
Take your spray arm and place it back in its original compartment. Do this by grabbing the edge and slowly pushing down with a bit of force.
2 участников успешно повторили данное руководство.
