Removing the Anti-Glare Coating from a MacBook Pro Screen
Выберете то, что вам нужно
  1. Removing the Anti-Glare Coating from a MacBook Pro Screen, Removing the Anti-Glare Coating from a MacBook Pro Screen: шаг 1, изображение 1 из 2 Removing the Anti-Glare Coating from a MacBook Pro Screen, Removing the Anti-Glare Coating from a MacBook Pro Screen: шаг 1, изображение 2 из 2
    • Power off the MacBook by clicking on the Apple logo in the top left corner of the screen. Then, scroll down the list and click "Shut Down."
    • Disconnect any attached cables such as chargers or wired headphones.
    • Disconnecting cables before beginning this repair is crucial to avoid moisture damage and electrical shocks. Cables should not be present in order to fully clean the ports and connectors.
  2. Removing the Anti-Glare Coating from a MacBook Pro Screen: шаг 2, изображение 1 из 2 Removing the Anti-Glare Coating from a MacBook Pro Screen: шаг 2, изображение 2 из 2
    • Gently wipe the screen's surface with either a microfiber cloth or cotton pad to remove any residual dust or oil.
  3. Removing the Anti-Glare Coating from a MacBook Pro Screen: шаг 3, изображение 1 из 1
    • Apply a mild plastic polish or cleaning solution like Bar Keeper’s Friend (liquid) to a cotton pad.
  4. Removing the Anti-Glare Coating from a MacBook Pro Screen: шаг 4, изображение 1 из 2 Removing the Anti-Glare Coating from a MacBook Pro Screen: шаг 4, изображение 2 из 2
    • Softly rub the coating from the cotton pad onto the MacBook's screen in small circular motions.
    • Be careful not to damage the screen underneath.
  5. Removing the Anti-Glare Coating from a MacBook Pro Screen: шаг 5, изображение 1 из 1
    • Wipe the screen clean with a new microfiber cloth or cotton pad. Inspect for remaining coating.
    • If the damaged anti-glare coating still remains, repeat this process as many times as needed.
Финишная прямая
Nicole Vo
Участник с: 05/12/25
121 Репутация
1 руководство автора
Команда
UC Davis, Team 1-4, Whithaus Spring 2025 Участник UC Davis, Team 1-4, Whithaus Spring 2025
UCD-WHITHAUS-S25S1G4
3 членов
Автор 1 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 52
За последние 30 дней: 280
За всё время: 1,537
