Введение
This guide will explain how to remove the display hinge. The tools required for this section are the spudger and the PH 2 screwdriver.
Выберете то, что вам нужно
Flip the Cinema Display so it is on its face and the feet are pointed away from you.
Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
Remove the back foot from the hinge mount by gently pulling it upwards.
Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
Lift the back plate off of the display.
Completely remove the back plate and set it aside.
Remove the Apple Display Connector plate screws (9.52 x 3.43 mm) with the PH 2 screwdriver.
Once the two screws have been removed, move the cord out of the way.
Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver.
Then lift out the hinge mount.
3 участников успешно повторили данное руководство.
