Запчасти
No parts specified.
  1. Remove the back two 14.0 mm Torx #10 screws.
    • Remove the back two 14.0 mm Torx #10 screws.
  2. Lay the printer on its back.
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  4. Open the frontal access panel by lifting it from the top.
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  5. Take out the two frontal 14.0 mm Torx #10 screws. Carefully lift the frontal cover. Don't lift it up aggressively. A strip will be attached to it.
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
Заключение
Justin Taiki Fukada
Участник с: 25.01.2014
822 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 1-41, Maness Winter 2014 Member of Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 22
