Выберете то, что вам нужно
Place the laptop upside down on a clean, flat surface.
Locate the battery release button with the padlock symbol above it.
Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
Gently remove the battery from the side of the laptop.
Turn the laptop upside down and locate the panel labeled C
Unscrew the single screw holding the cover in place.
Lift up the cover and remove it to expose the Modem Card.
Pull tab to lift the card out of the connector on the main board.
Disconnect the cable attached to the left edge of the Modem card
