Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Запчасти
Детали не указаны.
  1. Place the laptop upside down on a clean, flat surface. Locate the battery release button with the padlock symbol above it. Slide the battery release button towards the padlock symbol and hold it there.  Note that the button is spring loaded and will return if released.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Turn the laptop upside down and locate the panel labeled C Unscrew the single screw holding the cover in place. Lift up the cover and remove it to expose the Modem Card.
    • Turn the laptop upside down and locate the panel labeled C
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Modem Card.
  3. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  4. Locate the Modem card. Remove the screws.
    • Locate the Modem card.
    • Remove the screws.
  5. Pull tab to lift the card out of the connector on the main board. Disconnect the cable attached to the left edge of the Modem card
    • Pull tab to lift the card out of the connector on the main board.
    • Disconnect the cable attached to the left edge of the Modem card
Финишная черта
Lauren
Участник с: 25.04.2010
4 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 16-2, Maness Spring 2010 Участник Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 4,390
