Введение
This guide is base on the official service manual which I have attached to the device page and has been created using photos contained in other iFixit guides.
Запчасти
Никакие детали не требуются.
  1. Place the laptop upside down on a clean, flat surface. Locate the battery release button with the padlock symbol above it. Slide the battery release button towards the padlock symbol and hold it there.  Note that the button is spring loaded and will return if released.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Place laptop upsid down on a clean flat work surface. Remove the Philips M2.5 x 8 mm screw Loosen the screw that holds the memory compartment closed
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
Заключение
Richdave
Участник с: 09.04.2010
29 048 Репутация
Автор 30 руководств
Команда
Master Techs Member of Master Techs
Community
281 членов
Автор 792 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 6
За всё время: 368
