Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide is base on the official service manual which I have attached to the device page and has been created using photos contained in other iFixit guides.
Выберете то, что вам нужно
Place the laptop upside down on a clean, flat surface.
Locate the battery release button with the padlock symbol above it.
Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
Gently remove the battery from the side of the laptop.
Place laptop upsid down on a clean flat work surface.
Remove the Philips M2.5 x 8 mm screw
Loosen the screw that holds the memory compartment closed
remove the memory module compartment cover
Press the Optical Drive release lever to the right and the optical drive should slide out of the case
