Введение
This guide will show you how to remove the optical (cd) drive from your HP Compaq dx2000MT.
Запчасти
Никакие детали не требуются.
  1. Turn off your computer and remove the power cable by pulling it straight out of its socket.
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Remove the 2 Phillips #2 screws that secure the case door to the device. Remove the 2 Phillips #2 screws that secure the case door to the device.
    • Remove the 2 Phillips #2 screws that secure the case door to the device.
  3. Remove the side case door by pushing towards the rear of the device with your hand. This may take considerable force so keep pushing! Once you slide the door back, remove it by pulling it outwards from the device.
    • Remove the side case door by pushing towards the rear of the device with your hand.
      • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Remove the side case door by pushing towards the rear of the device with your hand. Once again, this may take considerable force. Once you slide the door back, remove it by pulling it outwards from the device.
      • Once again, this may take considerable force.
  6. Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive. Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive. Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  7. Remove the 2 Torx T15 screws holding the optical drive in place. Remove the 2 Torx T15 screws holding the optical drive in place.
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  8. Remove the other 2 Torx T15 screws holding the other side of the drive in place. Remove the other 2 Torx T15 screws holding the other side of the drive in place.
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  9. Remove the optical drive by sliding it out the front of the device. Remove the optical drive by sliding it out the front of the device. Remove the optical drive by sliding it out the front of the device.
    • Remove the optical drive by sliding it out the front of the device.
Заключение
Logan Pace
Участник с: 12.10.2011
2 020 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 17-16, Regan Fall 2011 Member of Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 членов
Автор 17 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 1,215
