Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Removing the Logitech MBJ58 Mouse Scroll Wheel
Выберете то, что вам нужно
  1. Removing the Logitech MBJ58 Mouse Scroll Wheel, Top cover: шаг 1, изображение 1 из 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Removing the Logitech MBJ58 Mouse Scroll Wheel: шаг 2, изображение 1 из 2 Removing the Logitech MBJ58 Mouse Scroll Wheel: шаг 2, изображение 2 из 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Removing the Logitech MBJ58 Mouse Scroll Wheel, Removing the Logitech MBJ58 Mouse Scroll Wheel: шаг 3, изображение 1 из 3 Removing the Logitech MBJ58 Mouse Scroll Wheel, Removing the Logitech MBJ58 Mouse Scroll Wheel: шаг 3, изображение 2 из 3 Removing the Logitech MBJ58 Mouse Scroll Wheel, Removing the Logitech MBJ58 Mouse Scroll Wheel: шаг 3, изображение 3 из 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
Заключение
5 участников успешно повторили данное руководство.
Conor Whatley
Участник с: 01/11/13
489 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 5-14, Forte Winter 2013 Участник Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 членов
Автор 21 руководств
2 Комментариев
Thanks! The picture was what I needed after the mouse wheel parts came apart. My mouse is an M-BT58, but based on the numbers on the circuit board, there are probably several that are essentially the same. For others, here are some more details on putting things back together.
The mouse wheel has 4 parts:
1) The wheel itself (really a rubber tire and plastic rim, but they stay together)
2) Plastic carrier for the wheel
3) A spring for controlling rotation of the scroll wheel. This spring is at the top of the picture shown.
4) A spring for controlling clicks of the scroll wheel, shown near the wire leading to the computer.
Reassembly
1) Put spring (3) on carrier (2). There is a hole where the very tip of the end without the loop fits in.
2) Push the shorter axle of the mouse wheel into the carrier slightly depressing spring (3) as it is inserted. Once the wheel is inserted, the spring will stay in place.
3) Put spring (4) on the longer axle of the mouse wheel.
4) Install the carrier into the base of the mouse.
Jim Monte - Ответить
I ran out of characters in the previous comment, but as you are installing the carrier into the base of the mouse, be sure to keep the spring (4) approximately as it is shown in the picture.
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 19
За всё время: 5,575
