Введение
You will learn how to remove scroll wheel from the wheel mount.
Запчасти
Детали не указаны.
  1. Hold the mouse so that the bottom is facing up.
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Place the mouse so that the bottom is resting against a hard surface. Lift the top cover of the mouse gently, and remove it.
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Locate the scroll wheel on the mouse. Grab the scroll wheel with your thumb and index finger. Gently lift up, to remove the scroll wheel from the mouse.
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Locate the spring on the scroll wheel, and carefully remove the spring. Locate the spring on the scroll wheel, and carefully remove the spring.
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down. Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Locate the black wheel mount. Note: Make sure that the spring hidden in the mount does not fall out. Separate the wheel from its mount.
    • Locate the black wheel mount.
    • Note: Make sure that the spring hidden in the mount does not fall out.
    • Separate the wheel from its mount.
Заключение
2 участников успешно повторили данное руководство.
Conor Whatley
Участник с: 11.01.2013
480 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 5-14, Forte Winter 2013 Участник Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 членов
Автор 7 руководств
Один комментарий
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
Антон Вакаренко - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 1,315
