Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
You will learn how to remove scroll wheel from the wheel mount.
Выберете то, что вам нужно
Hold the mouse so that the bottom is facing up.
Remove the single Phillips #1 screw from the bottom half of the mouse.
Place the mouse so that the bottom is resting against a hard surface.
Lift the top cover of the mouse gently, and remove it.
Locate the scroll wheel on the mouse.
Grab the scroll wheel with your thumb and index finger.
Gently lift up, to remove the scroll wheel from the mouse.
Locate the spring on the scroll wheel, and carefully remove the spring.
Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
2 участников успешно повторили данное руководство.
Один комментарий
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
