Выберете то, что вам нужно
Gently use tweezers to detach the white vision wire harness, located directly under the feed tube.
Remove the two 1-1/4" screws on either side of the circuit board using a 3/32" allen wrench.
Slide the metal body out of the plastic shell by holding one in each hand and gently pulling apart.
Почти готово!
Заключение
