Введение
This guide will instruct you on how to remove the fan blade and transformer.
Инструменты
Запчасти
No parts specified.
Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you may damage circuit elements.
In order to remove the fan blade pliers were used to remove the holding nut.
After the holding nut is loose, use the pliers to pull up to remove the nut.
Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
Use a pair of pliers to hold the nut at the bottom of the transformer, as you unscrew from left-to-right at the top of the transformer. After, pull up and remove both the screw and nut.
Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer.
The transformer should be free after this step.
