Введение
Utilisez ce tuto pour remplacer la pile PRAM (pile bouton CR 2032) de votre PlayStation 3 Slim.
Выберете то, что вам нужно
Retournez la PS3 et posez-la sur le dos.
Décollez soigneusement l'autocollant de garantie du boîtier inférieur pour accéder à un cache-vis.
Appuyez sur le mécanisme de verrouillage du connecteur d'entrée AC et tirez vers le haut pour le déconnecter de l'alimentation électrique.
Tout en maintenant le dispositif de retenue en plastique contre la carte, utilisez la pointe d'une spatule pour faire sortir la pile PRAM de son logement.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
24 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
9 Комментариев
ATTENTION: This guide is not valid for PS3 slim CECH-3004B!
from the number 11 you notice that your ps3 is different.
The CECH-3004B version does not give direct access to the 2032 battery.
You must also disassemble the motherboard from the grid (and all the pieces that obstruct this operation)
It is possible but it is more difficult
I found this to be the case too. Did you end up replacing the battery? If so, how did you do it?
Same for CECH-2501A, I got the blu-ray drive out and was greeted by a battery covered by the metal shielding. Have to go deeper...
It is kind of hard to tell by the photo alone: The plus (flat) side of the battery must face up when you insert it.
hey i need serious help i opened my super slim to replace the battery and could not figure how to get it out thought off lifting the socket might allow me to replace the battey much to my horror now socket is torn from the motherborad my console is stuck in black screen and a day before i tried to update from safe mode still a black screen now if i turn on the console i know its waiting for to confirm update iniatlization can i update the console without cmos battery or shomhow cancel it and be able to boot into recovery again
