Введение
Utilisez ce tutoriel pour remplacer le lecteur de disque Blu-ray de votre PS3. Le lecteur est un modèle Sony propriétaire.
Выберете то, что вам нужно
Retournez la PS3 et posez-la sur le dos.
Décollez soigneusement l'autocollant de garantie du boîtier inférieur pour accéder à un cache-vis.
Appuyez sur le mécanisme de verrouillage du connecteur d'entrée AC et tirez vers le haut pour le déconnecter de l'alimentation électrique.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
178 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
22 Комментариев
great work guys and ladies.......haha went without a snag!
I have a question I have followed your guide properly and removed my drive and found that the laser and disc loader are both need replaced. My question is when I go online and look for the replacement it sometimes shows just the laser then others shows the driver. I want the entire component as seen in this guide above. Do these come intact with everything in it when I buy it online. Can you please help.
Thank you,
Thomas Martinez
Tomlvgmartinez@yahoo.com
Ive been able to remove the drive and I think it's fixed. To get it back together how do you get that ribbon underneath to go back into the slot? Is there a trick? I can get it lined up, but it won't go in.
Thanks for the help
Ken,
Don' t know if this helps you now after all this time, but maybe it will help others with the same issue.
a) On the slot where the ribbon is to be inserted, is a lock clip. You pull up on that (gently).
b) Slide the ribbon in now with the clip lifted.
c) While securing the ribbon down in the slot, push the clip down, it will lock the ribbon in the slot.
Hopefully this helps, I didn't realize the clip could be lifted. While it's down, it is impossible to set the ribbon in.
ShuriKen
ShuriKen -
