Desktop PC Graphics Card Replacement
Выберете то, что вам нужно
  1. Desktop PC Graphics Card Replacement, Left Panel: шаг 1, изображение 1 из 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Graphics Card Replacement: шаг 2, изображение 1 из 2 Desktop PC Graphics Card Replacement: шаг 2, изображение 2 из 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Graphics Card Replacement, Graphics Card: шаг 3, изображение 1 из 1
    • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
    • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
  4. Desktop PC Graphics Card Replacement: шаг 4, изображение 1 из 2 Desktop PC Graphics Card Replacement: шаг 4, изображение 2 из 2
    • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
    • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
Заключение
83 человек успешно провели ремонт по этому руководству.
David Lennon
Участник с: 04/14/15
10 108 Репутация
Автор 10 руководств
Команду
Cal Poly, Team 4-5, Maness Spring 2015 Участник Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 членов
Автор 45 руководств
3Комментарии к руководству
There should be a notice about the PCI-E slot, which has a security latch; the latch should be pressed in order to remove the graphics card from the motherboard.
Onel Jimenez - Ответить
I have a all in one pc so this is not relevant
Robert Campanelli - Ответить
any diffrerences in slots?
benzy aceware - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 5
За последние 7 дней: 33
За последние 30 дней: 229
За всё время: 18,170
