Введение
Once the phone is disassembled, you can access the motherboard, replace the screen, or keyboard, and/or find other faults with the phone.
Запчасти
Никакие детали не требуются.
  1. Frontal view and rear view of the LG Net10 prior to disassembling. Frontal view and rear view of the LG Net10 prior to disassembling.
    • Frontal view and rear view of the LG Net10 prior to disassembling.
  2. Remove battery back cover by applying pressure along the groove.  The LG logo should be up right.  Apply the pressure downwards to remove the cover. Remove battery back cover by applying pressure along the groove.  The LG logo should be up right.  Apply the pressure downwards to remove the cover.
    • Remove battery back cover by applying pressure along the groove. The LG logo should be up right. Apply the pressure downwards to remove the cover.
  3. Remove the battery from the top of the battery. Remove the battery from the top of the battery.
    • Remove the battery from the top of the battery.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Remove the SIM card, by pushing down on the top of the SIM card and sliding it out from under the metal band.
    • Remove the SIM card, by pushing down on the top of the SIM card and sliding it out from under the metal band.
  6. Remove all four screws from the back of the phone by using a small Phillips head screwdriver and turning it counterclockwise. The screws are 0.5 centimeters.
    • Remove all four screws from the back of the phone by using a small Phillips head screwdriver and turning it counterclockwise.
    • The screws are 0.5 centimeters.
  7. Use a wedge, or flat edged tool to separate the phone.  Make sure to circle around the entire phone, especially the corners to pull it apart.  This can be difficult.  This may take several tries, so make sure to be persistent. Use a wedge, or flat edged tool to separate the phone.  Make sure to circle around the entire phone, especially the corners to pull it apart.  This can be difficult.  This may take several tries, so make sure to be persistent. Use a wedge, or flat edged tool to separate the phone.  Make sure to circle around the entire phone, especially the corners to pull it apart.  This can be difficult.  This may take several tries, so make sure to be persistent.
    • Use a wedge, or flat edged tool to separate the phone. Make sure to circle around the entire phone, especially the corners to pull it apart. This can be difficult. This may take several tries, so make sure to be persistent.
  8. Separate and remove the two hard covers and the keypad.
    • Separate and remove the two hard covers and the keypad.
  9. Then remove the motherboard from the hard back of the phone. Then remove the motherboard from the hard back of the phone.
    • Then remove the motherboard from the hard back of the phone.
  10. Once the phone is completely dissembled, you can replace the screen if it is cracked.  You can also replace the keypad if the buttons do not work or if there are other issues with the keypad.  Another common desire people have is to unlock the phone.  In order to do this, you must replace the SIM card, which is explained in the steps above.
    • Once the phone is completely dissembled, you can replace the screen if it is cracked. You can also replace the keypad if the buttons do not work or if there are other issues with the keypad. Another common desire people have is to unlock the phone. In order to do this, you must replace the SIM card, which is explained in the steps above.
Заключение
Gina
Участник с: 15.04.2013
125 Репутация
Автор 2 руководств
Команда
SUNY Cortland, Team 1-1, Getto Spring 2013 Member of SUNY Cortland, Team 1-1, Getto Spring 2013
SUNYCORT-GETTO-S13S1G1
4 членов
Автор 4 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 3
За всё время: 964
