Введение
After several years, the clock projector of my RRM320P was missing some segments.
Suspecting that issue could be related to some poor electrical contact I decided to try to repair it
Выберете то, что вам нужно
After removing the 2 screws on the bottom, carefully open the bottom frame, see location of the plastic snaps snaps
Removes the back panel, taking care of the other plastic snaps
The projector and its optics is shown in the blue square
cables are tied together with a simple ribbon, in general the inner construction seems very cheap
The Projector is made of three parts:
A red LED
The display with its controller
the lens with focus mechanics
All parts are kept by tiny screws that you have to remove
Take extra caution when handling the display, the flat cable is very weak and can be damaged by improper handling
Carefully remove display from its supporting frame
The issue should be ralated to flat cable connecting display to controller
Verify that moving the flat the display returns to work
put a stiffner on controller side and close to the display
if everything is working, reassemble the clock by doing the steps in reverse order
6 человек успешно провели ремонт по этому руководству.
6 Комментарии к руководству
my Peakeep clock keeps the correct time but you can't see the time clearly. It's as if the light is turned off.
Thank you for this post! It was the exact starting point to fix my projection clock which was looking dull and had lost a few segments. While the addition of supporting tape helped for a short period, doing it again in conjunction with Step 6 of the following link (http://www.instructables.com/id/How-to-r...) - Applying heat - to the ribbon contact points was the ticket that restored my projection clock functionality.
Hi Adam, glad to helped you
