Repairing Black and Decker BL3000S Power Cord
Выберете то, что вам нужно
  1. Repairing Black and Decker BL3000S Power Cord, Blender Base: шаг 1, изображение 1 из 2 Repairing Black and Decker BL3000S Power Cord, Blender Base: шаг 1, изображение 2 из 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Repairing Black and Decker BL3000S Power Cord: шаг 2, изображение 1 из 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Repairing Black and Decker BL3000S Power Cord: шаг 3, изображение 1 из 2 Repairing Black and Decker BL3000S Power Cord: шаг 3, изображение 2 из 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Repairing Black and Decker BL3000S Power Cord: шаг 4, изображение 1 из 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Repairing Black and Decker BL3000S Power Cord: шаг 5, изображение 1 из 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Repairing Black and Decker BL3000S Power Cord, Power Cord: шаг 6, изображение 1 из 1
    • Tug on wires in the marked locations to make sure they are secure.
    • If the wire stays still, the connection is secure.
    • If you still have problems with the blender, it is probably a problem with the motor. Since the motor is irreplaceable, you will have to order a new blender.
  7. Repairing Black and Decker BL3000S Power Cord: шаг 7, изображение 1 из 1
    • If the wire comes off, the connection is insecure. You will need to solder the connection to make it solid again.
    • If you don't know how to solder, here is a link to show you how. http://www.aaroncake.net/electronics/sol...
Заключение
4 участников успешно повторили данное руководство.
Elmer Pres Urbano
Участник с: 10/05/12
148 Репутация
1 руководство автора
Команда
Cal Poly, Team 6-34, Regan Fall 2012 Участник Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 14
За последние 30 дней: 36
За всё время: 3,892
