Repairing Canon Powershot Camera indicates low battery and shuts down
Выберете то, что вам нужно
  1. Repairing Canon Powershot Camera indicates low battery and shuts down, Repairing Canon Powershot Camera indicates low battery and shuts down: шаг 1, изображение 1 из 1
    • First you need to remove the back cover of the camera, so that you can access the motherboard. Here is how it looks like with the backcover removed (4 scew removed for a powershot A1200). At the top, you can see the main pins connecting the battery contact to the motheboard, but it is difficult to access them.
  2. Repairing Canon Powershot Camera indicates low battery and shuts down: шаг 2, изображение 1 из 2 Repairing Canon Powershot Camera indicates low battery and shuts down: шаг 2, изображение 2 из 2
    • Then, i remove the screen (2 screws), so that the motherboard and the connecting pins are easylly accessible.
    • In the second picture, you can see that near the pins, there is a "+" and a "-" sign. Here, by gently pressing them with a screwdriver, I noticed that one of them was completly loose. That is the reason of the problem.
    • Then, it is simple to fix it by soldering the loose connection.
    • The problems comes from the fact that the battery pins are directly solded to the motherboard, therefore the force exerted to maintain the good contact with the battery is applied to the soldering, which may eventually brake.
    • Next, remount every thing in back order. Pay attention to keep the screen clean (remove any fingerprints), and every thing should work fine...
Заключение
2 участников успешно повторили данное руководство.
Philiipe
Участник с: 11/01/13
183 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 29
За последние 30 дней: 72
За всё время: 30,320
