Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will show how to replace the speaker on the Casio camera
Выберете то, что вам нужно
Flip open the connector holding the ribbon.
Pull out the LCD screen with the ribbon from the camera.
Remove two screws on the side where the battery is located.
Remove the lanyard loop after the screws come off.
Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
On the front of the camera near the flash flip the connector holding the ribbon.
Remove the ribbon from the connector.
Carefully remove the L shaped frame from the camera
At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab.
Pop the frame off the bumps and tabs.
Note: There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
The blue box is the speaker
