Введение
A friend of mine had some issues with leaking water from the machine. So, we decided to try to repair it. With success :-)
Инструменты
Запчасти
Clean the inside of the cover, the rubber ring, the filter and the holder of the rubber and filter.
Put it all back together... First the filter, then the rubber ring... You need the smooth side of the ring facing up.
In case you notice the water seal rubber is broken or has tiny cuts in it. You can re-order part: MS-0907124 - Krups Seal
15 участников успешно повторили данное руководство.
Комментариев: 8
Hi! I do have that problem and that is probably the reason why it leaks as I live in an area of very hard water.I am trying to follow your instructions but I can find the right screwdriver to open it up.Do you know how do they call the bit I need to open it up?thanks
I think it's pierced star T10
Really helpful - thanks so much I think it has done the trick !
I didn't think I had the right screwdriver but then found it in a kit I bought recently.
Thanks! The same seal worked also with De Longhi EDG 600.B
Hi, just taken mine apart and although no crud on the seal I did notice that it was lower than the clear plastic suround it sits in. Either the seal isn't deep enough or its shrunk over time, hence the leak. Oh yes there are in fact 8 screw's in the black outer housing. Hope this helps.
