Выберете то, что вам нужно
Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
Remove battery, prying from the provided gap at the upper-right corner of the battery
Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures.
Start at the top, and work clockwise, being careful not to break the clips.
There are, 1, 3, 2, and 3 clips on each side, respectively.
After the clips are disengaged, there are no cables holding the back panel in place.
5 участников успешно повторили данное руководство.
